I am running KFLOP/KSTEP and want to be sure that I am correctly setting the value of parameter StepperAmplitude. An earlier discussion on this forum states that KSTEP is an open loop control, so it makes sense to set StepperAmplitude for the desired low frequency voltage and Lead for boost at higher running speed. I am working under the assumption that StepperAmplitude has modulus 256 (i.e., 8 bit resolution) but can no longer find the article in the documentation that would confirm this. I believe that the same article explains the relation of parameter Lead to the lead function time constant.
My steppers are 2.8 ohm/phase and are rated for 1.5 amps. I use a 24 volt supply. So if modulus 256 is correct, the value for StepperAmplitude should be
(2.8 ohm * 1.5 amp)/(24 volts) * 256 = 45
Questions are:
1. Where is the article that I vaguely recall, on the scaling of StepperAmplitude and Lead?
2. Is my calculation of StepperAmplitude correct?
3. What is the function of the current setting jumpers on the KSTEP board ? (I have them set at 1.25 amp)
Dave
